跳转到主内容
加入维修社区 - 创建账户
Kohler 为许多不同类型的乘骑式割草机和园林拖拉机生产燃油发动机,适用于家庭用户和专业人士。
Mower just clicks won't start
I have a cub cadet lt1050. It's been having problems starting so I replaced the battery and it worked for a while then it started having problems again and I would hammer on the starter to get it going. Now it won’t start no matter what I do. Ive tried jumping the selnoid and it still just clicks. What should I try next?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Don't ever bang on the starter believe it or not it's not good for it maybe tapping on the bottom is ok but you can seriously mess up the inside of the starter I went to pick up a starter whose been working on them for 35 years and over heard him telling someone else that
由完成的
Try turning the engine over by hand it might be the starter is locked into the flywheel
由完成的
添加一条评论
2个答案
已选择的解决方案
Hey Seth.
I’d just make sure the electrical connections between the battery, solenoid and starter are sound, and the battery is fully charged. If the key switch won’t start it, and your jumping the solenoid won’t either, then it’s almost sure the problem is with the starter. Sometimes the gear that engages the flywheel is made of plastic, and it wears over time, requiring replacement of the gear only, instead of the whole starter. Either way, the starter removal and installation is fairly straight forward and simple (don’t forget to remove the ground from the battery before you start).
Good Luck.
这个答案有帮助吗?
得分 1
添加一条评论
Starter Assist Relay should fix it up. Cheap fix.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Seth Gomez 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 47
总计 14,752
