跳转到主内容
This is a touchscreen tablet manufactured by Samsung that was released in September 2015.
45 个问题 查看全部
Is my digitizer broken and is it repairable?
So I stepped on my Galaxy Tab S2 (9.7) while it was facing screen down on my bedroom floor and I saw a spiral crack that wasn’t visible on the screen glass itself, but rather on a layer beneath the glass. I didn’t think much of it initially, because the screen functioned perfectly and the crack while large was only noticeable under direct light. Later that day I turned on the tablet and the entire screen had a bluish film over it and the tablet was having difficulty registering touches (I was however able to enter my pin after multiple tries to unlock the device). From the little knowledge I have regarding the internals of phones/tablets I believe I have a broken digitizer. I don’t think the screen is damaged because directly after I stepped on it the entire screen functioned flawlessly. So, is it possible to buy just this digitizer assembly independent of the screen, and is it replaceable? Or is more than just the digitizer damaged?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Hello,
in this case, proceed with following iFixit guide.
If you know the part number, search for spare LCD on the eBay, there are a low of different LCDs. But If you would like, you can search for parts on the rounded.com and order what you want.
这个答案有帮助吗?
得分 0
4条评论:
So in order to replace the digitizer I have to buy a digitizer+led screen unit, the digitizer isn't separate? If I have to buy a new screen with digitizer (those seem to be in the hundreds of dollars) I'd rather buy a brand new Samsung tablet in the mid 200s. Thanks for your response, I'm just trying to determine if a repair is cost-effective. I don't know if this is possible but I don't actually use the touch on the tablet I use a keyboard and mouse most of the time so if there's a way I could remove the digitizer from the screen that would also work. Thanks again for replying.
完成的
I have found some parts with the average cost about 12$. They are not the original parts, but it may be enough.
In many cases, repairing tablets are more expensive, then buying a new. Some company didn't produce spare parts for some "low-cost" devices, because of the manufacturing and storage - deliver cost.
完成的
Can you send me a link to one of these items you are finding for around $12 or at least what search terms you are using on what sites to find these items? I'm having trouble finding a digitizer for the Galaxy Tab S2 9.7 on Ebay and on rounded.com. My tablet model number is SM-T813. Thanks again for helping a stranger.
Edit: do you think the screen itself (AMOLED panel) is not damaged?
完成的
I've found the TOUCH SCREEN ONLY
https://www.aliexpress.com/item/32842605...
Is it what you are looking for?
完成的
添加一条评论
You need to replace your screen and digitizer.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sean Eddy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 29
总计 1,249
