跳转到主内容
Released in May 2018, identified by model number X410ULMG.
13 个问题 查看全部
My charger keeps falling out and it has to be just right to charge
My LG k30s charger won't fit into the charging port and I've used multiple chargers and it's the same with all of them. Ive looked up how to fix this and every article says there's dust and stuff inside my charger port…there is not, I even tried “removing" what what could've been there but there was nothing. This isn't a new phone or a new charger either. It worked and charged perfectly and then one day it became loose. Please help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
Do you have a case or rubber / plastic sleeve on phone? Try removing that and using a new micro usb charger not from 99 cents store they are made cheaply and easily break. I had same problem doing these 2 easy steps helped another tip dont use phone while charging!
这个答案有帮助吗?
得分 2
添加一条评论
From what you've described, your USB port is damaged. I had a similar problem with my Blackberry and the only successful repair was replacing the Port
这个答案有帮助吗?
得分 1
添加一条评论
My life sucks beacause of this
这个答案有帮助吗?
得分 0
1条评论:
Jacob Long unsuck your life and fix it:-) What phone? What issues? what have you tried?
完成的
添加一条评论
添加你的答案
cooper unkown 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 16
总计 2,596
