跳转到主内容
Comprehensive set of repair guides for playthings for children of all ages.
961 个问题 查看全部
Electronic toy cuts out after a few seconds
The toy in question is a Bright Starts Having A Ball Spin and Giggle Puppy. This toy has a spinning dish and plays a song as it goes. The purple component is the motor that powers the dish.
This toy cuts out every time after 2-3 seconds of being on. It plays the same introductory bit of its song, spins for 2 seconds then cuts out.
Is there anything I can tweak to make it work?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
In normal time what is the condition that makes him stop ?
完成的
It always stops after the motor has been spinning for a few seconds.
完成的
添加一条评论
2个答案
最有帮助的答案
So since the toy cuts off after being 2-3 seconds on, and the spinning bowl also cuts off with the audio, I would assume its a faulty connection. Meaning that the toy barely has enough power to play. Assuming that you already replaced the batteries, I would check the two gray buttons on either foot as a wire could be sliced or unsoldered there. I would also recommend to clean all 6 chipboards with rubbing alcohol and a q-tip as dust or dirt could prevent the toy from staying on. Make sure that the light from the nose and two paws are working and blinking as that could be the problem. I would also recommend lubricating the motor, as the motor could barely have the strength to keep turning. If there’s any corrosion in the battery case, clean it and check the red and black battery wires to make sure they aren’t damaged.
这个答案有帮助吗?
得分 1
添加一条评论
I know this sounds super simple, but have you tried replacing the AA batteries with some known, good batteries?
It sounds like a power issue, honestly, so those batteries inside it may be worn down so they’re only providing enough juice for 2-3 seconds of use. I figured it was worth asking since I didn’t see you mention that you’d replaced the batteries in it already.
这个答案有帮助吗?
得分 -1
添加一条评论
添加你的答案
sam.adams 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 38
总计 588
