跳转到主内容
任天堂 Switch 是一款可以通过扩展坞在电视和路上玩的游戏掌机。发布于2017年3月3日。
706 个问题 查看全部
Strange Issue With Nintendo switch not charging not and power on
I Buyed a Faulty nintendo switch from a friend , he say that wont charge anymore and not power on also said that when he plug into the dock the green light come up 1 time then goes off. I managed to replace the usb C Port which was broken , but still not charge or anything, the battery is deplated with a tester it shows a value under 3.7v ( i dont remember maybe was 2.7) managed to get up on .3.7 then i replugged the battery and drop down to 3.5v , but still not signs of power on im in holiday and when i’ll go home i try to switch the battery from a good one . The strange issue is that when i plug a low volt usb c charger ( not the original one) the (Orange Component) https://2.allegroimg.com/original/03fb0c... getting warm not so much like 34 celsius. any idea if the “ram” or cpu IDK is doing right or not ? and is the Battery dead ? Anyone had this problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I’m not an expert but from what I’ve learned this info might help:
If it’s not charging then it could be one the charging ICs is broken (the blue one in your image and the one above and to the left of it). The chips are called M92T36 (blue) and BQ24193 (top left). You could test for shorts on the capacitors around them, if there are any then the chip is likely broken.
Especially if your switch turns back on with a working charged battery then it is likely that replacing the broken chip will fix the issue.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Antonello Curci 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 19
总计 2,503
