跳转到主内容
Repair information and troubleshooting for the Dell Latitude E6430. This business class laptop has a 14 inch screen and uses a 3rd generation Intel Core processor. It was announced in May 2012.
Horizontal line going from end to end on the screen
I have a dell latitude e6430 and there is a line running from end to end on the screen. I think its stuck pixels. When the screen is white the line turns red and any other coulor the line is green. How can I fix this? (The line next to the queen playlist is just spotify.)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Just from the pictures I would say that there’s a problem with the LCD display itself. It is either a bad controller chip or the LCD element has pulled away from the contacts to the controller. I’m afraid it may not be repairable. Definitely check with Dell.
这个答案有帮助吗?
得分 2
2条评论:
It just fixed itself.
完成的
Glad to hear it but it probably won’t last. If it comes back try GENTLY squeezing it (front to back) on the edges where the defect is. This is a common aging problem with LCD displays. Replacement is about all you can do. Best of luck.
完成的
添加一条评论
You have a TAB (tape automated bonding) failure on the LCD. Even if it comes back temporarily, you need a new LCD, like it or not.
Refer to this video to replace the LCD.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Panayiotis Michalos 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 76
过去 30 天: 257
总计 1,164
