跳转到主内容
型号:A1419/ 2012/2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 专业版
My RAM won't get accepted.
Hey,
I installed Corsair RAM inside my iMac but all I get is the 3 beeps, pause, 3 beeps and repeat. I’ve verified on the Apple Discord that it is right for the iMac. I’ve also tried Crucial before. What do I need to repair?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
It’s fixed. It was a problem with the CPU socket. It’s now fully working again. I gave the board to a friend who a professional with logic boards and he fixed it in 5 minutes. The iMac is now fully working except for the missing display.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Your RAM need to be PC3-12800 DDR3 running at 1600 MHz double check.
The beep code is telling us your RAM is not compatible or is defective About Mac startup tones
Update (07/25/2019)
At this point I think you need to find someone local to you you can bring your system in to let them look at it. I fear you have damaged your logic board at this point. Hopefully you only have a mis-install of the modules.
这个答案有帮助吗?
得分 2
5条评论:
It is. The Crucial one was PC3L so I ordered a PC3 one which is the one that's currently installed.
完成的
There is no real difference between DDR3 and DDR3L in your system. The 'L is low voltage but it still will work in the older systems (backwards compatible)
完成的
I replaced it just to be sure it wasn’t the low voltage that’s causing the trouble but it seems that something else is causing it instead.
完成的
What happens when you put the old RAM back in?
完成的
No matter which slot or RAM stick I'm using, it won't work.
完成的
添加一条评论
Test with one stick in just one slot. Does it post? If not, try it in another slot. If still no luck, take another one of the new RAM sticks and repeat the process. The goal is to determine if you received defective RAM, or if one of your slots is potentially damaged. You may have also ordered the incorrect RAM. What speed is the new RAM? Try with one of your old sticks and one of your new sticks as well.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Can 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 156
