跳转到主内容
A portable Bluetooth speaker manufactured by Ultimate Ears.
60 个问题 查看全部
ue megaboom not working
My UE MEGABOOM will only work if it is plugged into a charger. It works perfectly fine when its plugged in as if it working normally. But as soon as it disconnects from the charger it turns off instantly as if it were broken. PLEASE HELP!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi Leroy
How long did you own the device? If it is still under warranty, send in for service….
Else you might want to open up to check the battery they have a lifespan....
Logitech UE MegaBoom Battery Replacement
There is a possibility the battery might be exhausted. If you have a spare battery, you can try replacing it and check if it works.
Else in worst case, the charging section might be having issues.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Leroy Veamatahau 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 72
