跳转到主内容
加入维修社区 - 创建账户
Logitech UE MegaBoom Battery Replacement
你所需要的
  1. Logitech UE MegaBoom Battery Replacement, Outer Mesh: 步骤 1 中的图像 1,3 Logitech UE MegaBoom Battery Replacement, Outer Mesh: 步骤 1 中的图像 2,3 Logitech UE MegaBoom Battery Replacement, Outer Mesh: 步骤 1 中的图像 3,3
    • Locate the ends of the speaker.
    • Put a plastic opening tool in-between the rubber end and the mesh.
    • Apply a upward force in order to pry open the end.
    • Apply this procedure to the other side as well.
    • Will take force.
    • Using metal tools may permanently mar your device.
  2. Logitech UE MegaBoom Battery Replacement: 步骤 2 中的图像 1,3 Logitech UE MegaBoom Battery Replacement: 步骤 2 中的图像 2,3 Logitech UE MegaBoom Battery Replacement: 步骤 2 中的图像 3,3
    • Take the Jimmy and pry up the rubber strip that has the volume buttons on it.
    • You will hear clicks as it pries up, don't worry.
    • Remove all the rubber you pried off.
  3. Logitech UE MegaBoom Battery Replacement: 步骤 3 中的图像 1,2 Logitech UE MegaBoom Battery Replacement: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    • Use tweezers to lift end of plastic retainer on edge of mesh out of its channel.
    • Work the plastic retainer out of the channel all the way around the speaker.
    • Be gentle, it is easy to damage the fabric.
    • Repeat for other side.
  4. Logitech UE MegaBoom Battery Replacement, Battery: 步骤 4 中的图像 1,1
    • Pull on white strip to remove battery.
    • Remove inner plastic gasket on circuit board.
    • Remove 2nd plastic gasket around outer circuit board edge, under rubber gasket.
    • Gently pry circuit board up out of recess.
结论
17等其他人完成本指南。
Oscar Ambriz
于09/27/17注册
978 声望
创作了6篇指南
团队
Cal Poly, Team S9-G2, Banghart Fall 2017 Cal Poly, Team S9-G2, Banghart Fall 2017 的会员
CPSU-BANGHART-F17S9G2
4 名成员
创作了17篇指南
24指南评论
There is a way to take it apart without all these steps and a complete tear down.
Brian Longhurst - 回复
How to ensure it’s waterproof upon reassembly?
mdeblasi - 回复
This is huge overkill. Only the bottom cap and circuit board need to be removed for a battery replacement.
coryjohnson011 - 回复
I agree. The battery is located on the bottom end only.
Jamin Hu -
^ the person who says that you only need to remove the one end-cap to replace the battery is correct. The process outlined in this article is more likely to damage all the fabric and other end-cap than just opening one end and gently prying it back until you can slide out the battery. FYI, the pull tab on my battery broke right off, and I had to pull it out with pliers.
sizz0p - 回复
添加评论
浏览统计数据:
过去 24 小时: 18
过去 7 天: 156
过去 30 天: 779
总计 64,592
