跳转到主内容
The third generation of the Samsung Galaxy Note phablet series released September 25, 2013. Identifiable by the model number N9005.
Microphone doesn't work after USB daughter board replaced
My old but reliable Note 3 charged slower and slower and then not at all. Probably due to dirt accumulated in the USB port. I bought and replaced the daughter board that includes the USB port and now it charges quickly. However now the microphone doesn’t work at all, but the speakerphone does when in phone mode. So now I can’t verbally input anything, e.g., text messages, search fields, voice commands….. There was some sticky, gray colored film between part of the board and the phone chassis to the right side of the USB port as you look down onto the back of the phone. I think it may have something to do with this. I disturbed the film when removing the old board but was careful to replace it as shown in the teardown video. Thanks for any help. (re: Right to Repair- I bought it, I own it, and I can do what I want with it (within FCC Rules & Regs) thank you very much!)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi Charles,
check out Microphone not working after charging port replacement and Microphone and/or speaker problem.
这个答案有帮助吗?
得分 1
2条评论:
Hey Lucas, thanks for the answer, I appreciate it. It gave me some insight and I'll try working on it some more. It seems a lot of newer "things" are made cheaper with a known inherent short life expectancy and I am better off if I can repair older "stuff". At least I don't feel like such a fool buying and throwing away the same crap over and over. Thanks again.....
完成的
Hi Charles, you are welcome, we are only humans, so keep going, fingers crossed!
完成的
添加一条评论
Just get another daughter board. Some of the new replacement board has bad mic from factory.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
charles drescher 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 460
