no green light on charging cable
macbook pro does not power up/turn on . No green light on charging cable
If that’s the case I would start off by inspecting the systems MagSafe connector making sure its clean and the metal contacts are not burnt.
Here is the replacement MacBook Pro Unibody 13" and 15" MagSafe DC-In Board and here’s the guide to replace it MacBook Pro 13" Unibody Mid 2010 DC-In Board Replacement
Given the age of the system you may also need a new battery MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Battery and here’s the guide to put it in MacBook Pro 13" Unibody 中期 2010 电池更换
产品
$9.99
产品
$69.99
指南
难度:
简单
10 minutes
指南
难度:
困难
45 minutes
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 40
Review this Apple T/N Apple Portables: Troubleshooting MagSafe adapters. Make sure the cable and the connector are in good shape and you have the correct charger as well for your system. Do make sure its a real Apple chargers as there are many fakes out there! OEM MagSafe Chargers vs Cheap Imposters: Teardown for Truth & Real vs Fake Magsafe 2 Charger Macbook Pro
由 Dan 完成的
the charging cable works on other macs, not on this one
由 Greg E Terres 完成的
