跳转到主内容
Repair guides for the 2018 version of the Samsung Galaxy A8 Android smartphone released in January 2018. Good features at a good price. Model Number SM-A530F
22 个问题 查看全部
My phone will charge when connected to a laptop but not to any charger
It will spam the moisture in the charging port sometimes or just not register the wall charger at all. But as soon as I plug it into my laptop while turned off it will charge just fine.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
3条评论
My phone does not recognise the wall charger. But the moment i plug it into a laptop for a second then replug into the wall charger it starts charging
完成的
same problem with me… 2 days ago mobile lower potion was exposed to water… not it is not charging with charger but charging with laptop. please tell me solution?
完成的
I am experiencing the same issue. How do I fix this? My phone only charges from the laptop...not the wall.
完成的
添加一条评论
2个答案
最有帮助的答案
There’s a chance that your media transfer only option is enabled. You should be able to swipe down from the top and see what method it’s using to connect via USB. Plug it into your computer and check, and change it to USB mode only if possible.
Hope this helps,
Austin
这个答案有帮助吗?
得分 4
2条评论:
thank you so much, i switched to charging-only option for USB and it's charging again!
完成的
how do I find this?
完成的
添加一条评论
Do a software update.... that may solve the problem
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jonathan Onuluk 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 79
过去 30 天: 459
总计 24,460
