跳转到主内容
加入维修社区 - 创建账户
InFocus LP540 是一款数字投影仪,提供视频和计算机输入功能。它具有 1024x768 的 XGA 分辨率。维修此设备需要螺丝刀及其他实用工具。
Bulb comes on; no menu available
I have an older InFocus projector (bought in 2005?). Haven’t used in a decade. I turned it on, the bulb lights up and projects on the wall, but that’s it. I can’t get it to even display a menu, and when I connect it to my MacBook, nothing new is displayed, just the square block of light from the bulb. Any thoughts on resurrecting this old projector? Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
I have exactly the same problem with an infocus LP130 that hasn't worked for 5 years. Are there any tests to do on the motherboard?
Could the DLP be HS?
由完成的
添加一条评论
1个答案
已选择的解决方案
Hi,
Just verifying that there is no indications at all when using the projector’s keys or the remote control buttons to see if the projector is responding to any user inputs? Stupid thought but pressing “blank” on the remote doesn’t restore the projector so that the menus now work or that there is an image displayed when connected to a computer?
If there is no responses at all I’m wondering if it may be a firmware problem and hopefully not a hardware problem.
Here’s a link to the firmware update for the projector. (scroll do to the Downloads section). The download file incorporates a pdf document along with the firmware that explains how to update the firmware. Just trying to do this may give an indication whether the projector still has some life.
If there is no response at all when trying this perhaps it may be a hardware problem, i.e. a faulty motherboard. After 10 years of non-use, components may have deteriorated or have been affected by the environment where the projector was stored.
Here’s a link to the ifixit InFocus LP540 guide which should be of some help in gaining access to the internal components for an initial inspection.
I cannot find a service manual online for the projector, you may have better luck.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
fiddler5000 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 20
总计 869
