跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
How can I remove the metal bracket covering the tristar?
So I have to run a jumper from u4500-B3 to L4522, but L4522 it fully covered by the metal bracket. Should I just cut the bracket off in that area, or can you take the bracket off, and put it back on later? Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
In my opinion it’s much better to just cut off the needed part, if you have a decent tool for the job you are sure to avoid damaging the board. Removing the metal frame it’s not that hard but you can almost forget to be able to solder it back without making a mess..just my 2 cents ;)
这个答案有帮助吗?
得分 3
2条评论:
Also be careful as there is a glass-bodied MOSFET just underneath the shield and it is very easy to damage when tearing off the shield.
完成的
@refectio Think it would be best to get a little dremel tool, and try and be very delicate?
完成的
添加一条评论
添加你的答案
Ben Parkinson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 75
