跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
Why can't I update my iPhone 6
My iPhone 6 has been having issues since I had it and restarts at random points, sometimes even going into a bootloop. Since I couldn’t update from iOS 9 wirelessly, I plugged in my phone to my PC and attempted to update it. However, I guess it went into a bootloop mid way and caused the phone to erase and not be able to load off any iOS software at all. I tried to update it from iTunes and 3u.com but it still runs into problems. Does this mean its bricked?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
My computer is recognizing it only when the restore screen is showing. It’s just that since the phone restarts at random moments, it cuts off the process.
完成的
添加一条评论
2个答案
已选择的解决方案
It might be a simple battery issue, if peak power provided is insufficient for the task the iPhone may easily reboot. Give it a check when you have 3Utools running, it will give you some insight about it.
这个答案有帮助吗?
得分 3
1条评论:
I can’t check any iPhone info because it sticks to recovery mode and only shows the flash menu.
完成的
添加一条评论
It seems that the phone is still recognized by a PC, right?
Any specific error from i tunes?
What is the OS in the PC? when you plugged the phone e.g if windows 10 it will try to trabsfer e.g photos to your PC from the phone.
Could be the PC is infected, run an antyi-virus.
After re-install iTunes, the latest if you don’t have it.
I suppose iTunes can see the phone. Have you try to do a complete restore?
Also call Apple (not an apple store) they can add some more help.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
michael2006leon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 139
