跳转到主内容
加入维修社区 - 创建账户
The Chevrolet Equinox is a compact crossover SUV from Chevrolet based on General Motors's Theta unibody platform, and introduced in 2004 for the 2005 model year.
How to check fluid level on transmission
2013 how too check transmission fluid
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Where is transmission dip stick located
完成的
There's no dipstick,under the car, there's a bolt, a lady can't get to that,but I myself watched my dad,I can't afford 400 to a mechanic. I'm going to do it.ty to those who showed me on here.
完成的
添加一条评论
3个答案
已选择的解决方案
You cannot check or add fluid as described there is no dipstick that you can just grab and check fluid! You have to get under the car and remove an engine mount to get to the dipstick which bolted in with 12mm bolt ! It is a poorly designed transmission with no fill tube for easy access. $250-$400 for transmission service!
这个答案有帮助吗?
得分 4
2条评论:
You literally remove 1 7/16 bold plug my guy.
完成的
Thus engine and transmission is GMs' most defective ever
完成的
添加一条评论
Transmission Fluid Level Check Chevrolet Equinox (2010-2017)
  1. Getting Started.
  2. Open the Hood.
  3. Remove Dipstick. Access point for transmission fluid.
  4. Check Level. Insert dipstick and pull it out to determine level.
  5. Add Fluid. Determine correct fluid type and add fluid.
  6. Replace Dipstick. Put the dipstick / cap back in place.
  7. More Info. Additional information on checking trans. fluid levels.
  8. https://www.carcarekiosk.com/video/2012_...
这个答案有帮助吗?
得分 2
5条评论:
There is no DIPSTICK on the 2011 Chev Equinox!!
完成的
^^this^ and this answer should be removed
完成的
You couldn't be much more wrong than you are.
完成的
You know, people rely on this information to be correct it's crazy that this got by somehow. This answer may be right on 99% of vehicles but the Chevy equinox is not one of them. Because it has no dipstick. It has a sealed system that forces these car buyers to take it to a shop to check the transmission that's crazy. And in mechanic terms that can cost a car buyer from 200 to $400 just to check it.
完成的
The 2006 Equinox dip stick is in the front by the fans at the bottom of the engine.. it's bright yellow and has one bolt on the left hand side of the dip stick this is also the same spot to fill your transmission fluid to.. if you have long arms you can get to it from the top.. but most ppl do it from under the car
完成的
添加一条评论
You have to remove 3-4 bolts off of the cover underneath the car. You cannot access your dipstick without removing that cover and will have to have it on a lift to get an accurate reading of the fluid level. Look for the full video on YouTube. ”How to service Chevy Equinox transmission fluid by Santer Auto Repair LLC.
这个答案有帮助吗?
得分 2
1条评论:
how can i fix the 2020 transmission fluid and change the fluid
完成的
添加一条评论
添加你的答案
kdanno9865 将永远感激不已
浏览统计数据:
过去 24 小时: 8
过去 7 天: 24
过去 30 天: 131
总计 42,803
