跳转到主内容
The Xbox 360 is the second game console made by Microsoft, and was released November 22, 2005.
428 个问题 查看全部
Why is my 360 restarting over and over.
So i have an old 360 and i havent touched it in awhile but recently we want to use it for netflix. It updated after connecting it to the wifi. And then after turning it on now it will run for a little bit then make a click sound and power off and restart, turning itself back on. It will stay on if i dont run any app or game, somtimes. But as soon or shortly after starting a app it will make the click sound and restart. I took it apart and cleaned the years of dust out of it and put it back together and it still does it. Id like to know what i can do to fix it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Is your Xbox the only thing connected to the Power outlet. Or is there anything blocking airflow in the case.
Are you using the power brick that came with it. Because if not it may be a voltage issue. Thus the Xbox may be restarting for its own safety. Wipe off the power button. Any loose debris can cause the Xbox to falsely mistake it for a finger.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Zach R. 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 102
