跳转到主内容
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
383 个问题 查看全部
Replaced Harddrive with SSD and drive not being recognized
I replaced the hard drive with a SSD on my imac, 27”.  I copied the old hard drive before I started.  Replaced drive with SSD from ifixit upon reboot it is not recognizing it, tried to do a time machine recovery but new drive not recognized to write to.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
You need to format the drive GUID Mac Extended Journaled before you start or your Mac will not see it internally. Use Disk Utilities to do this.
I would format the drive first, then install the system. Now use Migration Assistant to move your data. This way the Repair Partition gets installed.
这个答案有帮助吗?
得分 2
2条评论:
Similar problem but when I run Disk Utility it only recognizes the external backup drive and NOT the new SSD.
完成的
@irvsnyder Please start a new question on this as the advent of Mojave and Catalina and the new APSF formatting has introduced new problems when install and recognizing non-APSF formatted external drives.
完成的
添加一条评论
添加你的答案
gretchen 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 5
总计 57
