跳转到主内容
Why is there ice in vent from freezer to fridge?
I have ice in the hole which brings air from freezer to fridge. My freezer is good, but my fridge food is spoiling. Help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Damper Control Assembly
The air damper control opens and closes to let the proper amount of cold air into the refrigerator compartment. If the damper does not open properly, it won’t let enough cold air into the refrigerator. Check the damper control to determine if it is broken or stuck closed.
I’d use a hair dryer to defrost the damper and then look for a source for the water leak that froze it up.
If the damper needs replacing, please give a model number so I can locate the part.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Darlene McClure 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 4,160
