跳转到主内容
Repair and disassembly guides and support for dish washing appliances.
707 个问题 查看全部
Whirlpool model wdt790sayb3 won't spray water
My Whirlpool dishwasher will fill with water and go through the drain cycles. I can hear the electronics triggering, but it will not spray water. I replaced the inlet water valve, and that corrected the initial filling problem. But I still do not get water spraying from the jets. I checked to ensure that there is nothing clogging the jets or in the drain, I have also confirmed that the float is not obstructed or stuck. I have read multiple reviews on here regarding the door latch, door switch, or pump assembly. I simply do not know where to go with troubleshooting to determine if it is one of these three, or another problem. Please offer help or ask further questions if I need to provide more detail. Thank you.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Lots of causes for this. Start here so you can get a better idea of how it works and what parts are involved.
Please give us your model number.
https://www.repairclinic.com/RepairHelp/...
这个答案有帮助吗?
得分 2
1条评论:
The model number is wdt790sayb3 . I've already replaced the water inlet valve, and checked all the spray heads. I'm trying to determine if anyone knows if there is a way to trouble shoot between the door switch or door latch (both inexpensive fixes) or the pump and motor assembly (expensive fix). Thanks.
完成的
添加一条评论
Hey Cody.
Might want to consider obstructed or defective spray arm tube. This part delivers water to the spray arms.
这个答案有帮助吗?
得分 1
1条评论:
Seriously make sure the latch on the door is shutting. It's more than likely literally that simple
完成的
添加一条评论
添加你的答案
Cody Honl 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 501
