跳转到主内容
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
299 个问题 查看全部
IPad Air Charger Not Charging but Charger Port and Battery seem Fine?
Hi, so my iPad air A1474 is not charging but works and screen turns on but whats weird is I looked inside charger port and seems clean and when power off and plug in charger port it powers on but still doesn’t charge battery.
I decided to change charger port with a new one but still got same issue as seen in this video I made: https://www.dropbox.com/s/0o0truk0dh4hvq...
Does anyone know what the issue might be and how to fix it?
Thank you in advance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
You probably have a faulty charging circuit..it doesn’t seem to be a battery issue. It may be the Tristar which is quite a common failure when low quality chargers/cables are used..or a bad Tigris, or anything around the two, there’s no way to tell without accurate testing.
这个答案有帮助吗?
得分 2
2条评论:
@arbaman How would I test to see if it is tristar that is causing the issue?
完成的
@unicronman You will need schematics, board view file and a multimeter to start with. Probe battery pins, if you have no voltage or random voltage then you should get deeper into charging circuit and try to find out what's out of range..usual troublesooting steps, resistors, shorted caps, etc..
完成的
添加一条评论
添加你的答案
Cameron Saman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 211
