跳转到主内容
Repair guides and support for the first generation Nissan Murano, from the 2003 model year to 2007.
19 个问题 查看全部
Why did all transmission fluid run out of car
I was driving and all the transmission fluid ran out from under my car
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
2005 nissan murano
完成的
Usually with a sudden loss of trans fluid, you want to check the transmission cooling connections as these hoses often crack and leak, or something kicked up from road and punctured hose as they are exposed under car, depending on which motor. It is easy to see where leak is when examining hose connections to cooler, or cooler can also leak.
完成的
添加一条评论
3个答案
已选择的解决方案
The 3 Most Common Leaks
Although there are multiple places on a vehicle where transmission fluid can leak, the 3 most common include:
  1. Pan gasket
  2. Cooler lines
  3. Output, tail, or torque converter seal
A few other sources of leaks that are not as common include a rusted trans pan, damaged torque converter, external sensor housing, tail housing gasket, side cover gasket, filler tube, cracked case, etc.   These are not typically as common, unless you are driving an older Ford Taurus with the AX4N or AX4S transmission, as these are notorious for grooved torque converters which will cause excessive fluid leaks.
这个答案有帮助吗?
得分 3
添加一条评论
A sudden loss of transmission fluid usually ends up with something from the road you hit which punctured the aluminum pan, seen it a hundred times, so you have to get under vehicle to examine. Blown seals usually leak slowly, but above all, do not try to drive vehicle with no fluid or even low fluid, especially Nissans for they have very problematic issues with even low fluid failures.
这个答案有帮助吗?
得分 1
添加一条评论
Unless you hit a rock or some object which punctured your aluminum transmission or pan, the only other reason would be the transmission fluid cooler which has inlets and outlet tubes which often leak with age. So if you see trans oil under vehicle more than a small puddle every time you park, then it is something to check to see where trans fluid is coming from. Do not drive without fluid or your transmission will be shot and destroyed.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
tammy Saulsberry 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 27
总计 1,680
