跳转到主内容
电脑制造商联想所生产的台式机的维修和支持指南。
Why does my computer constantly whirl and make noise?
all in one computer, very loud and slow when machine is whirling.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Joe Pierce what model is your computer and what have you checked?
完成的
添加一条评论
2个答案
已选择的解决方案
This to me sounds like a possible cooling issue. The system probably needs to be cleaned out. Ideally the best option is to open the system up as much as you can and clean any dust out. At the very least try to use come compressed air. Just be careful of sensitive components.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Do you have the model of the all in one computer?
There should be a sticker label with the model of it behind the computer or in a removable cover.
Some models are built with very low end performing hardware. E.g like an AMD A4 processor and a 5200RPM 500GB laptop hard drive which will cause the computer to run very slow.
Does it run slow from the very beginning where it loads windows and using it in general?
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Joe Pierce 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 440
