跳转到主内容
A1706/EMC 3071—于2017年6月上市,这台13''MacBook Pro以可升级至3.5Ghz酷睿i7动态超频至4.0GHz的Kaby Lake处理器为特征。
276 个问题 查看全部
Why my touchbar have a purple tint around the icon?
I have an MBP 13" 2017 , which recently started showing a purple tint around the touch bar icons. It looks there is some sort of issue with it, as at times it just fades and flickers. Every function on the touch bar works as it is supposed to but there is some kind of issue with it.
I have tried booting in safe mode, resetting SMC, NVRAM but the issue is still there. Finally, after a few chats with Apple support, I completely wiped out and did a fresh install of the OS. And after everything, the issue is still there. So it looks like it is some sort of hardware related failure.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
Having the same issue on just 15 days old machine. I got 16 inch MacBook Pro on 6th January 2020 and experiencing the same issue now.
完成的
@Erick Bassan - Time to visit an Apple Store or authorized service center
完成的
添加一条评论
1个答案
已选择的解决方案
I’m not very familiar with touchbar build, but I’d say you’re definitely right, looks like a hardware issue. Hard to tell if it ‘s the touchbar itself or some circuit feeding power/data to it. I’m afraid Apple would charge an arm and a leg to fix that. The other alternative would be find some independent lab into component level repairs but that’s not going to be very cheap either. It’s a bit alarming such a thing may happen on a less than 2 years old machine.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Bara Limbong 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 12
总计 610
