跳转到主内容
此为等候许久的Mac mini硬件更新。处理器方面支持选配3.6GHz四核i3,3.0GHz六核i5,及3.2GHz六核i7英特尔CPU。
85 个问题 查看全部
Startup loading bar blank screen
When startup, the loading bar reach 70%. The monitor turns to save mode and blank screen. Press monitor power button. Turn off and then turn on again. The login screen is appeared. How to fix it?
更新 (2019年07月01日)
cannot fix the issue.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
First try starting in Safe Mode to see if you have extension issues.
Boot up holding down the Shift key.
Next see if you can boot to the repair portion.
Hold down the Option key on boot and see if you can select the Repair Partition. If you can, then run Disk Utilities.
这个答案有帮助吗?
得分 3
2条评论:
完成的
Given the age of the system it should still be under warranty. I would visit an Apple Store or authorized services center to get it repaired.
It sounds like your storage has a defect unlike the older mini's the storage this series uses an intergraded flash array via a T2 controller. Your logic board will need to be replaced.
完成的
添加一条评论
添加你的答案
Tommy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 141
