跳转到主内容
Dryer does not display correct time for selector switch setting
We had a brief electrical outage when our dryer was working - I was actually in front of the dryer taking clothes out (on timed dry cycle ) and the dryer beeped, all the lights lit up and it powered off, then on. No dryer error codes were displayed. When it powered on, I noticed that the time on the display no longer corresponds to the setting on the selector switch. For instance, the timed dry setting used to be 12 minutes but now shows 3 dashes on the display. Other cycles are similarly affected. The small load setting also shows 3 dashes as does the towels setting. Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Try resetting it by unplugging it from the wall for ten minutes.
UPDATE
Your control board may be fried. Please give us your model number so we can locate the part needed.
这个答案有帮助吗?
得分 3
1条评论:
Thanks for the tip. I unplugged it for an hour, powered it up, no luck. Also tried running a load and tripping the breaker - dryer correctly showed a Power Fail code but still does not function correctly. Time for a service call.
完成的
添加一条评论
添加你的答案
Kirby Kroon 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 6
总计 55
