跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
facetime camera not working, earpiece is.
So, I replaced the camera lense on the main camera and after that, 4 days. the customer comes back, facetime camera does not work.
I have tried about 10 facetime flexes and no result on camera.
earspeaker, proximity sensor works perfectly.
What is this, how do I fix this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
It would be surprising if you had 10 defective FCAM flexes. Still, you should test them in another, known-good device to be certain. However, IMO, you have a logic board issue and you need to start investigating the FCAM circuit. Start with checking all the relevant power lines (see image below).
Then check the rest of the connector (J4503) against known-good values (ZXW).
这个答案有帮助吗?
得分 3
4条评论:
But is it possible for me to destroy something like that by replacing the lense of the main camera?
完成的
My guess is possibly pry damage near the front camera connector? It would be small components around the FCAM connector that may be dislodged, missing or damaged.
完成的
Than you so much, Minho and Ben.. I'll have a look after the customer resets the phone and brings it back.
完成的
I'll update once I manage to fix it :)
With cause and fix :)
完成的
添加一条评论
添加你的答案
nicolay.94 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 94
