跳转到主内容
Model A1297 / 2.66, 2.8, 2.93, or 3.06 GHz Core 2 Duo processor
1004 个问题 查看全部
MacBook only works when power adapter is plugged in
I have a refurbished MacBook Pro that will only turn on when plugged in. It says it has 100% battery, but dies instantly if the power cable is unplugged. I have tried resetting the SMC and PRAM. I’ve included a screenshot of coconut report and the system information for the battery:
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Battery seems to be faulty, there are 2 values well out of standards:
  • voltage is not supposed to be 5v. but 8v. There’s some tolerance downwards but 5v. is much too low to keep the machine up and running.
  • Capacity is suspiciously on the high side. As you can see it reads 16,400mAH. A typical value should be around 12500mAh. I can understand some seller might set theorical capacity a bit higher, but this seems a bit too much.
However, even if we take capacity off the picture, voltage on its own says it all.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
jdr1984 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 507
