跳转到主内容
extremely stripped fan screw
I tried literally everything: bigger bit, super glue, rubber band, duct tape, compressed air.
I’m not sure what should I do right now, because I just don’t know how that screw extraction kit works, as there are no videos on YouTube about it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Use a Dremel type tool and cut a slot in it so a flathead can remove it.
Here’s a video on doing it:
https://www.youtube.com/watch?v=KQ0zHPPA...
这个答案有帮助吗?
得分 3
2条评论:
The fan is over it, I don't think Dremel could work, unless I cut the fan
完成的
Remove the speaker and you should be able to access it without damaging the fan.
完成的
添加一条评论
添加你的答案
Zigmantas Sabaliauskas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 99
