跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
1185 个问题 查看全部
MacBook a1502 early 2015no power
My macbook suddenly died mag safe turn green then orange sometimes fan spin , cpu gets little hot , mouse clicks and usb powers on usb mouse so i was wondering if any one had any idea on what to try since the macbook won’t even chime
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Try resetting SMC and PRAM, that’s about all you can do. CPU should be alive if mouse is powered on. If you do get back the boot chime but screen stays black try plugging your Mac to a screen/TV to see if you have an image there. If you have no boot chime even after resetting PRAM there’s a serious issue at board level to deal with, but that needs more indepth troubleshooting that requires tools and skills. However, it doesn’t seem to be a power issue.
这个答案有帮助吗?
得分 2
2条评论:
nop sometimes when i reset smc with the instruction that has pusingthe power button for 15 sec the fan powers in high revs do you think is a ppbus problem?
完成的
@carlos_15 The 10" power button pressing followed by plugging in Magsafe is a SMC bypass, the reset is done by pressing left shift+ctrl+alt+power button for 1". If it starts with first method and full speed fans there's a SMC issue.
完成的
添加一条评论
添加你的答案
carlos 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 115
