跳转到主内容
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
781 个问题 查看全部
Disk won’t eject. Motor turns on but nothing happens.
I put a game in to play and when I wanted to change games, I properly quit the current game and hit the eject button and I heard the disk drive door open, the motor kicked on and sound like it was ejecting the disk but nothing happened. How can I fix this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Do you have the fat, slim or super slim PS3? Model Number?
完成的
I have the slim. Model number CECH-3001B
完成的
添加一条评论
2个答案
已选择的解决方案
This link will show you how to manually remove a disc from a PS3 Slim.
If that doesn’t work, here is an alternative method that will void the warranty, if it’s still under one.
You may want to look into replacing the drive if you do end up taking the PS3 Slim apart.
Here is a guide for replacing the drive. And this is the drive you would need.
Post here again if you have more questions.
PlayStation 3 Slim Blu-ray Disc Drive图片
指南
PlayStation 3 Slim Blu-ray Disc Drive Replacement
难度:
中等
30 minutes - 1 hour
PlayStation 3 Slim图片
指南
PlayStation 3 Slim - Manually Removing Stuck Disk
难度:
中等
20 - 45 minutes
这个答案有帮助吗?
得分 0
1条评论:
Thank you for the help
完成的
添加一条评论
最有帮助的答案
I've heard that over time the rollers in the disk drives can become worn out. You might need to take the disk drive out and see if that might be the case. They can also just be really dirty so you might just clean them if they. There should be plenty of guides online for this. Here's an iFixit guide showing how to remove the drive PS3的蓝光驱动器更换
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
williameaton50 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 14
过去 30 天: 49
总计 4,014
