跳转到主内容
Why Can't I upgrade my 2010 MacBook Pro to 16gb?
I have a mid 2010 13” MacBook Pro. 2.4GHz Core 2 Duo, running High Sierra 10.13.6.
  • Boot Rom 66.0.0.0.0
  • SMC 1.62f7
I recently purchased a RAM upgrade 8 GB x2 SO-DIMMs to get to 16 GB (1066 MHz).
But when I install them my Mac won’t start up. If I use the stock 2 GB memory it starts just fine.
I have tried every combination of sticks and slots, but it will only work at the max of 10 GB. Please help.
Update (06/18/2019)
Model Identifier is MacBookPro7,1 the other numbers are in the original post.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
4条评论
Curious if you got anywhere with this. I have basically the same issues (Boot ROM 67.0.0.0.0 is the only difference), and I would love to figure out how to get the EFI update to work.
2x4GB DIMMs have worked fine for years. 2x8GB doesn’t. I may try to mix and see if I can get to 12GB.
完成的
12GB worked, but I could never get 2x8GB working. I bought chips from a different vendor and those worked perfectly. *shrug*
完成的
+1 to Steve. See comment on guide:
MacBook Pro 13" Unibody Mid 2010 RAM Replacement
完成的
添加一条评论
3个答案
最有帮助的答案
Could be a bad slot or your EFI didn’t get upgraded. Go “about this Mac” memory and see what each slot is reading. It looks like it is reading one as 8 GB and the other as 2. Remove the stick that is reading as 8 and reboot with just the one remaining stick still in it and tell us what it reads.
UPDATE
Use these steps to check your Mac's EFI Boot ROM and SMC firmware versions.
  1. Open System Information. Apple Menu > About this Mac > Overview > System report.
  2. Select the Hardware section to view the Model Identifier, Boot ROM version, and SMC version numbers.
  3. MacBook Pro (13-inch, Mid 2010)MacBookPro7,1MBP71.0039.B0E (EFI 2.5)1.62f7 (SMC 1.6)
  4. https://support.apple.com/kb/DL1478?loca...
  5. https://support.apple.com/kb/DL1626?loca...
这个答案有帮助吗?
得分 4
11条评论:
It reads both slots properly. If I swap the 8gb and the 2gb it will read them properly is each slot. If it restart it with either of the 8gb it reads them both properly in either slot.
The problem occurs when I try to run both 8gb together.
完成的
Neither of those updates are supported because I am running High Sierra and I cannot upgrade to Mojave, because the video card does not support "Metal"
完成的
My Boot Rom doesn't even start with MBP
完成的
MBP stands for Mac Book Pro. The Boot ROM is 71.0039. You are running 66. You did not do your system updates incrementally so you missed the EFI updates.
完成的
Any other suggestions?
完成的
显示更多的6条评论
添加一条评论
I had these same symptoms on my machine. See comment on guide:
这个答案有帮助吗?
得分 2
添加一条评论
I loosen the screw where you put the cards in then reinstalled 2 x 8 GB then rebooted the beebs stopped and it started up! So happy! see video about loosening the screws to card section if computer beeping on you tube.
Saved Mr from sending it back to owc.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Lucas Pinckard 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 3,457
