跳转到主内容
所有的苹果便携式平板电脑的全面维修手册。维修过程可能需要加热以及细心的撬动。
5769 个问题 查看全部
Charging issues on Ipad devices
lately we have been getting in iPad air’s and iPad Pro’s with charging issues we start with replacing the charging port then if that doesn’t work we try the battery and then the charging IC but we have noticed that none of these are fixing it. Has anyone else had similar issues and if you have were you able to find a fix?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I can’t speak for the Pro but on the iPad Air, the problem is usually with the charge port or the battery. By charging IC, I presume you are referring to the Tristar IC. However, I have not seen much success when changing that IC. When the problem persists, it is usually the PMIC. However, they are a more challenging repair and the replacement cost of a PMIC can be quite high so not all customers agree to the repair for such an old device.
这个答案有帮助吗?
得分 4
1条评论:
What is the charge for this PMIC repair ? I am having a similar problem.
完成的
添加一条评论
添加你的答案
Jonathan Pegues 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 8
总计 231
