跳转到主内容
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
1624 个问题 查看全部
Missing solder pad and resistor R6700, headphones are not recognized
I am trying to repair my MacBook which for over a year has not been able to recognize my headphones. I checked all the resistors filters and found R6700 missing. It might have fell off for whatever reason. I tried to reattach r6700 from a donor board but ended up making things much worse by losing one of the solder pads after I ran flux and solder over it. It just peeled off after I ran fresh solder on it. This was at a temperature of about 170 C (might be too low?).
Is there any way to fix the trace?
The highlighted pad is missing. Could I run a jumper from the highlighted pin to R6700?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
On the left of pin 1 of R6700 you have about 1 cm rail connecting the pad to the rest of circuit. Clean the area, use a good light source and some magnification and you’ll see the rail quite clearly. Scratch a bit its surface until you see the copper. Maybe there’s no need for a jumper either, unless you pulled the rail together with the pad, solder by itself should be enough to do the job properly. Temperature is way to low even for a solder iron, it should be in the range 290/320 if you use leaded tin , some more for lead free. That depends much on size of iron, station precision and so on..but 170C isn’t enough even to melt the solder wire.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Justin Ash 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 81
