跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
If my iPhone fell in the water and it wont charge or open
I tried to c harge it but still a blank black screen , after it fell in the water it turned to rainbow color with some types of lines and when the battery turned off it wont charge.
i went to the maintenance and they told me they need to change the power ic , some kind of chip that controls the battery and the life of the iphone , is that the correct way to repair my IPHONE 6S.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
A liquid damaged phone is usually a big headache, especially if it fell into a water basin. It should be properly decontaminated by removing its core, the mother/logic board, and after ultrasonic cleaning it, the damage can be tentatively assessed. It takes quite a bit of work even before the repair can actually begin.
I’ve seen phone boards that have been thrown into an ultrasonic bath as they were, without removing protective shields, which is a bit like expecting to clean oneself just by getting under the shower fully dressed, shoes and hat included. Maybe fun, but little efficient
Getting concerned about which parts needs to be replaced is a useless exercise, no phone is damaged exactly the same way as another and nobody can question what was found in your phone without looking at it under a microscope. I’d suggest to look into other more important details..will your data be retained after repair, what warranty is the lab supplying, how much do they charge, is it worth from an economic prospective ?
这个答案有帮助吗?
得分 3
1条评论:
Well they already told me no data will be deleted but the power of the mobile wont open or charge , they cleaned the water off properly and then told me about the problem of it that nothing will get deleted and its a matter of changing the power ic
完成的
添加一条评论
添加你的答案
Maya sol 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 48
