跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
iPhone 7 No power or charging after screen replacement
Hello
First off thank you for taking your time to look at my question.
So I had a cracked iPhone 7 and bought the new screen from a trusted website, and did everything as I should of but after putting the new screen back on it had no power, wouldn’t charge, not connecting to iTunes and not resetting/restarting. So I’ve took it apart again and noticed a tiny rip in the home button ribbon cable. Would that affect the phone switching on or just the home button?
I’ve swapped it back to the old screen but still nothing?
Any help is appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The Touch ID and home button won’t work and you’ll have to use assistive touch. Only apple can fix it. Make sure you plug in all of the connectors the right way. Hold the power down for a while. Also make sure you didn’t accidentally disconnect the charging port.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Stuart 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 62
