跳转到主内容
Repair information and guides for the 2015 Retina MacBook Air. Model A1534
281 个问题 查看全部
Thick purple bars when screen is at certain angles, normal other angle
2015 12 inch MacBook retina is showing thick purple bars on the screen when it is at certain positions/angles and is showing normal screen at other positions/angles. Rebooting and clearing NVRAM does not change it. The issues seems highly sensitive to the position of the screen, what angle it is at.
Everything else is functioning properly(keyboard, mouse, internet..etc) as far as I can tell.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
It doesn’t look like a GPU issue but just to be on the safe side when the glitch appears try connecting your Mac to an external display/TV to get the confirmation that artifacts are limited to the screen. If that’s the case it might be the cable or the screen are failing and need to be replaced.
这个答案有帮助吗?
得分 2
2条评论:
The mac does output normal video to an external display so at least that is working. Is there any way to tell what component of the screen/cable assembly is failing?
完成的
@fleeses Besides try and error none that I know of unfortunately.
完成的
添加一条评论
添加你的答案
Ronny 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 15
总计 1,799
