跳转到主内容
加入维修社区 - 创建账户
Released May 2004. Identified by model number T42 of the ThinkPad T40 series.
问题已关闭
wireless will not connect
I have an old T42 that connects with cable but will not connect using wireless. I checked drivers and even unistalled wireless controller and reinstalled it. It sees the wireless network but will not connect. I even tried a USB wireless divice and that could not get an IP either. It is running XP. Any jelp would be appreciated Bgaddis@aol.com
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
If it sees the network but does not connect, I would definitely check on your settings from your wireless router and compare it to what you have on your IBM.
完成的
添加一条评论
3个答案
For sure check your security settings on the wireless network you are trying to connect to. Many older devices/network cards cannot connect to some of the newer encryption methods.
这个答案有帮助吗?
得分 0
添加一条评论
If you can´t get an IP from your Router and cheked that the SSID and password is correct, it seems like the routers mac-adress filter is active or the Router is set so, that it doesn´t allows connections from "unknown" devices.
这个答案有帮助吗?
得分 0
添加一条评论
Please check security type
First make the routers network unsecured
If its done check whether u r able to go online wireless
Then we can isolate the problem
If u get online,prob with the sec type
If not online,check the settings of ur router
Some routers may have an option like Access control list
Check if ur router has that option enabled
If its enabled,disable it
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 12
总计 4,376
