跳转到主内容
A1708/EMC 3164—于2017年6月上市,这台入门级MacBook Pro保留了它的传统功能键(相对于OLED触控条)。
563 个问题 查看全部
How can I adapt this PCIe NVMe 256GB SSD?
This Macbook Pro 13” 2017 had a particularly strange drive I need to get data off. For the life of me I cannot find an enclosure or adapter for it.
Anyone seen anything like that? Or am I going to have to buy another machine to get at the data?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
7条评论
Can you tell us what happened, give us details we might have other alternatives.
完成的
Poor customer with no backup went to apple and they said of course we can fix the failed logic board but we won't back up your data. Such a crazy thing to tell your customer, this poor girl; We have to help her. So I will buy another machine from apple refurb and use it to recover the data. Then return it to them and tell them its crap.
完成的
And to add insult to injury...
https://www.macrumors.com/2018/11/09/app...
完成的
@heavylabs - Did you check if the system is covered? 13-inch MacBook Pro (non Touch Bar) Solid-State Drive Service Program I forgot about that program.
完成的
As it turns out the drive has also failed and yes this machine is a part of the "Apple's Homemade SSD That Sucked" replacement program. This girl will lose her data now or face a very very expensive recovery.
完成的
显示更多的2条评论
添加一条评论
3个答案
已选择的解决方案
You are absolutely justified in your pain. Apple giving us no recourse to recover data is total disregard for the needs of their customers.
Please join us to help secure your rights:
https://ifixit.org/right
@kyle Is there any other recourse that you are aware of?
这个答案有帮助吗?
得分 3
1条评论:
Done! With 25 years in the tech support and sales business, 10 years ago I was sick of the wasteful attitude promoted by corporations. Each day I do my best to convince people to repair repair repair.
完成的
添加一条评论
Sadly, its a custom Apple SSD! So far I don’t know of any case or adapter to support it so you can access the data on it.
But with that said! You do have one other option renting or buying another 13” MacBook Pro Fn system and carefully sliding out the SSD so you can plug yours in then using an external drive coming the data off.
Do make sure you’ve fully powered down the system before removing the SSD so you don’t damage it.
这个答案有帮助吗?
得分 2
1条评论:
Apple refurb department is about to get a return 2 days later ;) Found exact model
完成的
添加一条评论
Hi,
I have a MacBook Pro 2017 (Function keys) and I had an accident (water dropping) and the screen and connections are damaged. I couldn’t find affordable fixing, so right now is broken but the SSD works.
I bought a Lenovo A340-24IWL and I’d like to know if is possible to put the SSD from my broken MacBook Pro on this Lenovo A340? Do you have some enclosure or adapter to use this SSD on a PC?
Thank you very much for your response!!!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chris D 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 1,380
