跳转到主内容
A laptop computer series by HP. The numbers and letters that follow "G60" usually indicate what retailer sold it and what hardware it contains.
5 个问题 查看全部
Can't access documents on my HP G50-126NR, says security problems.
it fell and would not turn on. 5 months later i charged it for a cuple of hours and when i turned it on , it gave me a black screen with pointer. i ctrl-alt-del and restared it set it up to safe mode everything came up but took 10min or so to load then then stoped working and said it faild to created a security ___. then it went black with pointer. i turned it off and on it went striagt to my setting skipping the log on page. took another 10min or so to load the start and when i click the document program it says windows explorer stoped working( i did not click on any internet window) is it fixable?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
char, from what I read on here it sounds like you are having software and not hard ware issues. I would start off with reinstalling the Windows OS. The black screen with a pointer only, as well as all the other errors, seem typically of windows having issues with some of the system files. It is possible that the "fall" of your computer causes some read/write issue on the hard drive. Reformat it when you install windows. Good Luck and I hope this helps. BTW the windows explorer issue is not related to internet explorer, those are separate explorer's ;-)
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
char 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 290
