跳转到主内容
Refrigerators produced by Samsung.
250 个问题 查看全部
Freezer is working but not fridge
My freezer is cold but not my fridge and it doesn’t sound like anything is working, no noise just silent. I took apart the back, cleaned out all the dust around the coils, plugged back in and I just hear a clicking sound when I plug in but nothing turn on but the light. I thought maybe the compressor is bad but then why would the freezer still be working? I don’t hear the fan turning on either. ShouldI defrost, plug back in and see if that helps..I have a Samsung Fridge, any advice?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Cause 1
The Evaporator Coils are Frosted Over
The defrost heater assembly turns on a few times throughout the day to melt away any frost that may have accumulated on the evaporator coils. If the defrost heater assembly is defective, frost will continue to accumulate on the evaporator coils, and the coils will become plugged with frost. If the evaporator coils are frosted over, the airflow through the coils will be restricted, causing the refrigerator not to cool. Check the evaporator coils to determine if they are frosted over. If the evaporator coils are frosted over, test each component of the defrost system.
Cause 2
Evaporator Fan Motor
The evaporator fan motor draws cold air over the evaporator coils and circulates it throughout the freezer. If the evaporator fan is not working, the freezer or refrigerator will not cool adequately. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, replace the fan motor. Additionally, if the motor is unusually noisy, replace it. Finally, if the motor does not run at all, use a multimeter to test the motor windings for continuity. If the windings do not have continuity, replace the evaporator fan motor..
Cause 3
Damper Control Assembly
The air damper control opens and closes to let the proper amount of cold air into the refrigerator compartment. If the damper does not open properly, it won’t let enough cold air into the refrigerator. Check the damper control to determine if it is broken or stuck closed.
这个答案有帮助吗?
得分 2
1条评论:
What did you end up doing to fix your issue?
完成的
添加一条评论
添加你的答案
Karen 将永远感激不已
浏览统计数据:
过去 24 小时: 15
过去 7 天: 130
过去 30 天: 649
总计 20,656
