跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
1TB SSD replacement doesn't fit
I bought the OWC Aura Pro X2 SSD that is supposed to fit as a replacement for my MacBook Pro (early 2015 13” retina), but the shape is different and doesn’t fit into the slot. Is there another one that I can get that will fit?
Edit: Pics added on 6/10
The narrower (Samsung) is the original drive, and the wide (OWC) one is the replacement. The overall width of the part that goes in the slot is the same, but the notch is in a different spot. I tried turning it over just to check, but the replacement won’t fit either way.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Here's a good reference The Ultimate Guide to Apple’s Proprietary SSDs
Also review the OWC site OWC Solid State Drives For MacBook Pro with Retina Display (Late 2013 - 2015) to make sure you got the correct drive.
完成的
添加一条评论
2个答案
最有帮助的答案
Can you explain what is causing it not to fit. Are you putting it in correctly? The connector is keyed so it will only go in one way (right side up). The blade SSD does need to be the narrow version not the wide version. Did you get the wide one?
这个答案有帮助吗?
得分 2
9条评论:
he got an m2. it simply needs the apple drive
完成的
@tomfixee - "OWC Aura Pro X2 SSD" is a custom Apple SSD.
完成的
Hi there, it doesn't fit because the notch doesn't align where it's supposed to, and it's too wide to fit into the slot even if the notch did align.
完成的
Sounds like you got the wrong SSD! Some how you got an M.2 version instead of the Apple custom. Contact OWC to get it exchanged.
完成的
Dan, I chose the one right on the ifixit page for my model... and the one I received looks like the one on their page. So either they have listed the wrong SSD or there are different versions of my model. I've got a better idea of what to look for now, thanks fellas.
完成的
显示更多的4条评论
添加一条评论
Googling that seems to be an M2. That goes in a slot. Since I am not experienced in mac repair, If there is no m2 slot, no fit. I have seen a case that mac doesnt hae m2.
MBP early 2015 SSD can upgrade with Samsung 950 pro?
should help you, check Kulvinder Singh ‘s answer. I am not experienced in mac repair. I am a pc maker.
Update (06/08/2019)
This is the part that will fit MacBook Air 11" (2013-2015) 13" (2013-2017) MacBook Pro Retina 13" and 15" (2015) SSD
Replace or upgrade your solid-state drive.图片
产品
$39.99
这个答案有帮助吗?
得分 0
5条评论:
@tomfixee - The PCIe blade slot is not M.2 it's a custom Apple SSD slot.
完成的
see my edit.
完成的
@tomfixee If you don't know what you are talking about, please don't talk. We have real experts on the site to answers these types of questions.
完成的
@mayer wow, you are so rude. No need to be that mad.. hahaha you made my day
完成的
Hi guys, thanks for the links and input. I assumed that the SSD on the ifixit page for my model would fit, but I'll have to do some digging. Tom, the drive in the link you put in your update looks like my original one. Unfortunately they are out of stock in the larger capacity ones.
完成的
添加一条评论
添加你的答案
Nathen Clerici 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 1,100
