Touch ID failed after battery replacement
I did the correct procedure, removing battery cable, then the 3 connectors with the screen. Put in the new batt and put everything back together. Turn on - no Touch ID :(
Seems I was quite unfortunate here as everyone else having Touch ID problems have done a screen change and/or usually not disconnected a battery before doing a fix.
The home button’s working fine. I’ve also tried disassembling again and undoing the home button ribbon connector then reconnecting and reassembling… still no dice.
Any suggestions? Perhaps I can order a cable and swap it out. I’m aware from reading other posts, that a home button swap would need to be performed by Apple to retain Touch ID.
