跳转到主内容
The iMac G5, powered by the PowerPC G5 processor, was originally released in August 2004.
453 个问题 查看全部
Why does my screen have patches of white pixels in patterns.
It works in every way with the exception of some screen anomalies. It has little patches of white pixels in patterns about 3" apart vertically. Do you think it's the inverter board, memory or power supply? Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
can you take a picture and add it to your post. i've never seen this issue myself. Maybe somebody else has seen it before.
完成的
Condition has gotten worse, I had a spare PowerSupply and memory. Neither corrected the issue. However now the unit will start to boot, even lets me choose alternate boot devices, go black and raise the fan speed. Until I unplug it or hold the Start button powering it off.
完成的
添加一条评论
2个答案
已选择的解决方案
Please open the back of your machine and inspect the capacitors for swelling and/or corrosion. See if your serial number (located on the bottom of the stand) falls within these ranges:
Serial Number ranges:
W8435xxxxxx – W8522xxxxxx
QP435xxxxxx – QP522xxxxxx
CK435xxxxxx – CK522xxxxxx
YD435xxxxxx – YD522xxxxxx
这个答案有帮助吗?
得分 3
4条评论:
W84510VES9T is in the first set of SN, what is the significance?
完成的
Of the 16 capacitors on the right all look good. However of the seven on the left 5 are swelled.
完成的
For all the information and more on this problem go to Jim Warholics site: http://jimwarholic.com/2008/07/how-to-re...
Personally I found a place in Utah via eBay that fixes the G5 boards for $85. I sent in a couple and one is working fine and the other is about 95%.
完成的
Doing this repair yourself is a real PITA. Do a search on this site for "capacitors" and you will see loads of questions on this problem.
完成的
添加一条评论
I would lean more towards the inverter or the whole screen itself. If the pixels ever turn solid black then it's most likely the display itself suffering from pixels dying.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
steve bass 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 800
