跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
Randomly died and not turning on...
Hey I have an iPhone 6s here…
anyways, the customer brought it in for repair and the phone has no prior water damage. He said he used cheap cables and yesterday he left it off charge and 10 minutes later he comes back and the phone is dead..
i changed the battery and its it’s still not turning on. I also tested the battery connector while plugged in with battery removed and it measures 0volts. Is this a short on vcc main or a tristar issue?
the ampmeter shows 0 amps also….
Can someone tell me what I need to check and how to go about this procedure to resolve this issue…
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Cheap cables and a dead phone = Tristar.
If you suspect a short on VCC_MAIN, you should probe it with your multimeter to confirm it or rule it out. But realistically, this is a Tristar issue or a charge circuit issue (Tristar/Tigris).
这个答案有帮助吗?
得分 3
3条评论:
Can I pull a tristar out of another phone and solder it? What phones have the same u2 IC?
完成的
The tristar charging chip has balls under it which can't be resoldered properly without recalling it. It requires a hot air rework station and a stencil to recall and put back on the board.
What we do is buy the replacement charging chips preballed as it saves time and is more reliable.
完成的
@benjamen50 I love reballing such small ICs as much as I hate doing it on a PMIC ;)
完成的
添加一条评论
添加你的答案
Daniel Ringuette 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 50
