跳转到主内容
The iRobot Roomba 960 is a robot vacuum cleaner created by iRobot first released in July of 2016.
11 个问题 查看全部
Roomba side brush is making noise after replacement.
Roomba 960 making noise after side brush replacement.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Take it out and follow the guide on replacing it. Look for any broken parts:
iRobot Roomba 960 Side-Brush Replacement
这个答案有帮助吗?
得分 1
添加一条评论
Roomba 960 side brush was making a click click noise. Motor working fine. I took the brush off and a little WD-40 sprayed inside and brush put back on. Solution was a simple fix and wanted to share in case it helps.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
derrel.chappell 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 23
总计 5,763
