跳转到主内容
Model A1311 / Mid 2010 / 3.06 & 3.2 GHz Core i3 or 3.6 GHz Core i5 Processor
342 个问题 查看全部
after shutdown iMac,later it will not start up anymore
after shutdown iMac... it won't startup anymore.. but leave alone after 30minutes or 45 minutes(sometimes 2hours) it show startup!!
I just bought for 6months
why doesn't it boot? does power supply failed?
please kinda help.. I'm Newbie of Mac
thankyou..
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Some component is overheating. It should still be under warranty, contact Apple for a free repair. Here's where to get them: http://support.apple.com/kb/HE57
这个答案有帮助吗?
得分 3
1条评论:
you might be able to fix it yourself if it's just dusty. you will not be able to do a full job without opening it, which if it's still under warranty i do not recommend doing yourself. Using a can of compressed air, blow on the bottom of the iMac and the intake vent on the back of the imac (behind the foot). also blow some air into the exhaust, that's the long slit on hte back of the iMac. if you see lots of dust comming out you might want to get it opened and cleaned at an apple certified servicer.
Mayer is correct through in getting it checked at an Apple servicer, as if the dust is really bad, which at the point of overheating to shut down it most likely is, you might have some serious damage.
完成的
添加一条评论
添加你的答案
Taurenchiff 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,998
