跳转到主内容
Model Number: U405D-S2902, Processor: AMD Turion™ X2 Dual-Core Mobile Processor RM-72,
3 个问题 查看全部
Backlight flickers whenever display is at certain angles
First off, my laptop is actually a U505, not 405. There’s no listing for it, so I had to choose this.
As my question says, the backlight will occasionally die whenever the display’s at a certain angle. It also will sometimes cut out and the laptop has to be restarted to get it back.
The hinges are loose, and I can’t seem to find the original screws.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It is likely the power wires going to the backlight. The position of the hinge will vary the stress on these wires. Take off the shroud around the screen and look at the wires going to the backlight. The wires are usually white & pink. These wires carry high voltage so be sure to remove the battery pack prior to touching them.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jessica Parnelli Fawkes 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 70
