跳转到主内容
Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
586 个问题 查看全部
Only starts if I first disconnect battery for a few seconds
I have a mid 2011 MacBook Pro which shows green light on mag, but will only boot if I disconnect the battery for a few seconds. I tried 2 different batteries, both show over 95% design capacity. The laptop boots with just mag power after a few seconds without battery. I have continuously unplug the battery to get it to start. However, restart seems to work OK. Baffling...yes it is the dreaded 820-2915 but this is not kernel panicking…yet. Actually was able to run “Heaven “on it, so GPU seems fine for now.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Ever spilled anything on the keyboard, sounds shorted out to me.
Let’s take a better look at it. Please run Coconut Battery and post your results.
https://www.coconut-flavour.com/coconutb...
这个答案有帮助吗?
得分 4
1条评论:
Hey Mayer, as usual, you rock. I did put the logic board into another A1286 case, therefore another keyboard, and the issue is resolved. Humble bow into your general direction,
完成的
添加一条评论
添加你的答案
Jurgen 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 63
