跳转到主内容
加入维修社区 - 创建账户
A Touchscreen Notebook that was created by HP in 2014 for computing and processing.
Laptop won't connect to wifi
It didn't have my hp model as an option but it's a 15-ba049ca . It shows WiFi networks that are available and allows me to put my password in to connect but then it like stops. The available networks disappear and then reappear again but still won't let me connect. I have no idea how to fix this and would appreciate some guidance on what to do!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
When you check the Network with your phone or another device, do you see the same signal intensity? like the same bars, if you see low signal in your computer and high signal in your phone, that can be a loose connection with the Wi-Fi antennas to the Wi-Fi Card.
完成的
It is the same intensity or my phone has one less bar. Is that still the same issue?
完成的
Maybe you need to reinstall the wireless driver.
完成的
I've done that unfortunately, I also updated them and still nothing
完成的
添加一条评论
2个答案
已选择的解决方案
Hi Nicole,
  • First you need to download the latest drives but not install.
  • Now completely uninstalled the current driver and run something like Ccleanerto clean up any traces.
  • Reboot and then install the new driver.
  • Why this way? If there is a corrupt setting or the like re-installing, as expalined above, will just perpetuate the problem.
  • Let us know how it goes.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Hi Nicole
Have you tried to use a usb wireless dongle and try? it could be that your internal network card could be faulty, or a dry joint contact on the board.
Regards
Mckenzie
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Nicole 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 507
